![]() Join Date: Jul 2012
anybody got banski rear suspension on their Z? thoughts?
have heard some coilovers will interfere with clamp on trailing arms? |
#2 | |
I am running DRM coil overs and there are no problem with clearance with my Banski trailing arms
![]() Join Date: Feb 2012
![]() Join Date: Aug 2013
Full Banski rear suspension together with Coilover kit from DRM, no clearance problems at all.
If you like I can send pictures to you.... |
![]() Join Date: Jan 2004
love the banski stuff. the parts are high quality, much lighter than stock, and the heim joints eliminate the "sticktion" caused by the rubber bushings rubbing the mounting bracked to free up the rear travel tremendously.
I haven't yet seen if it helps the 60 ft time and the diggs but the handling and ride is noticeable better. I have the DRM shocks and indeed did have some problems with the springs rubbing the half shafts until I fiddled with the spring a bit. overall I'd for sure do the banski stuff, really like their products. |
Are you guys with the banski stuff using the drm brackets as well?
