Old 05-12-2017   #1
S.hafsmo
S.hafsmo's Avatar
Default Blue ALDL wire connected to ground
I've just discovered that someone has installed some sort of jumper between the blue wire on the ALDL connector and ground. Anyone care to guess what half-assed repair has been attempted? No fault codes appear when the jumper is removed.
The blue wire acc. to FSM,
SUPPLEMENTAL INFLATABLE RESTRAINT
(SIR)~ SERIAL DATA RECEIVE DIAGNOSTIC
ENABLE
Is it an attempted bypass on a poorly grounded sensor?
- '90 ZR-1
S.hafsmo is offline   Reply With Quote
