05-09-2017 | #1 |
Throttle Body Primary Blade Wear Issue
In the process of rehabbing a high mileage (120K) TB I acquired a while back.
Found the primary throttle blade worn down significantly on one side due to side forces coming from worn actuator cam follower. Before removing the throttle blade screws I used a Dermal with a small cut-off disk to grind off the retainer welds on the back side so not to ruin the throttle shaft threads.
05-09-2017 | #2 |
Re: Throttle Body Primary Blade Wear Issue
Is all that really worn off? Is there no notch on other side of the disk?
Remarkable. Makes sense one would have idle issues if the primary looks like that.
- '90 ZR-1 |
05-09-2017 | #3 |
What mine looks like at almost 70,000 miles.....not sure what the substance is on the edge of the blade and around the screw. Need to do a closer inspection, but that is probably the last thing I will do, wait til after the plenum is reinstalled....
Tom 1994 ZR-1 #009 "captured test fleet car" 1974 LS4 454 Vert 1982 L83 CFI...now a retired "dd"....Sold WAZOO Member |
05-09-2017 | #4 |
05-09-2017 | #5 |
05-10-2017 | #6 |
Phil,
If you've still got the throttlebody in your hands, could you take a pic of it underside, where the makers logo is?
- '90 ZR-1 |
05-10-2017 | #7 |
Here you go
Phil Wasinger 1994 Torch Red ZR-1 WAZOO Member George Braml Intake Last edited by Jagdpanzer; 05-10-2017 at 08:49 AM. |
05-10-2017 | #8 |
- '90 ZR-1 |
05-10-2017 | #9 |
05-10-2017 | #10 |
Doubt if there are any OE spares around. Could fab up a 10 degree angle mandrel and turn out a few new ones on the lathe. A good project for next winter.
