Old 04-07-2017   #1
902066
Default Plugging water passage in injector housing.
When reading the systems elimination article on this subject, I thought they said to use 1/8 inch plugs in the housings. I just tapped and plugged mine using a 1/16 inch plug. I didn't have to start by reaming the hole to fit a bigger 1/8 inch plug. All I had to do is tap the hole as is and put in the 1/16 inch plug. The new plugs are 5/8 inch long, go all the way in flush, are nice and tight, have Permatex thread sealer on them. I don't see why this wont work just fine, anybody done this? agree or disagree? Jim
902066 is offline   Reply With Quote
Old 04-07-2017   #2
Default Re: Plugging water passage in injector housing.
that should be just fine
Old 04-07-2017   #3
Concur with -=JEFF=- you should be GTG
Old 04-07-2017   #4
902066
Thanks you two, confirmation is what I was looking for. Jim
