I was wondering if anyone knows what has to be done to make the Z06/Z07 brakes work with Shelby Series One wheels. I've been told a spacer will work but I'm not into that solution. I have also been told that you can move the center of the wheel from the back of the barrel to the front. Does anyone have any experience with this application? What are you guys running for brakes with the Shelby wheel? Thanks in advance for your help.
![]() Join Date: Dec 2007
I was going to go down this road but went with GS calipers instead to avoid the hassle and guess work here is what the end result is
![]() ![]() Sent from my iPhone using ZR-1 Net Registry
90 Chevy ZR1 LPE #2315 'SOLD' 90 Chevy ZR1 LPE #2774 'SOLD' 91 Chevy ZR1 Callaway aerobody 91 Chevy ZR1 #1512 91 Chevy ZR1 #951 95 Chevy ZR1 #338 'SOLD' 91 BMW 850i 94 BMW 850csi 95 BMW 850csi 94 Lotus Esprit S4 07 Benz CLS550 06 BMW M5 "SOLD" |
Nice. i currently have the same set up on my car. Thanks
#4 | |
![]() Join Date: Jun 2005
yes, that is correct. I believe the rotor is slightly thicker on the Z07 RPO. Thanks
The C6 and C7 carbon brakes use huge rotors, special pads and speciifc calipers. Adapting them to the C4 suspension may be a challenge.
The first thing you need is a ton of money because to buy those parts will run into some serious bucks, perhaps 10 large. Secondly, you'll need at least 19" wheels to clear the calipers and then you need to determine the offset. Third, you may need to change the master cylinder as the stock C4 master may not work with that system. Fourth, you may have replumb some of the brake hydraulics' I should add that, if you do decide to go "all-in" and put carbon brakes on your ZR1, you'll have more brakes than you ever thought possible. On the other hand...if you suddenly develop a case of a really tight budget during tax season, consider my C4 brake upgrade for sale in the parts and cars for sale forum. ![]()
Hib Halverson Technical Writer former owner 95 VIN 0140 current owner 19 VIN 1878 Last edited by Hib Halverson; 03-21-2017 at 08:06 PM. Reason: added content. |
