Old 03-17-2017   #1
Blackbelt
Default Paul's dipstick bracket still available?
Proud new ZR-1 owner.
Getting ready to do headers. Bought the obx headers. Been reading about "Paul's dipstick bracket" for header install. Will I need this? How do I go about getting one from him? I tried messaging him but maybe it was wrong person.
Anything else I'll need? (Ordering new gaskets from Jerry of course)
Blackbelt is offline   Reply With Quote
Old 03-17-2017   #2
Ami Workman
Ami Workman's Avatar
Default Re: Paul's dipstick bracket still available?
I just let him know...so he should be getting with you!
Ami Workman is offline   Reply With Quote
Old 03-17-2017   #3
Yes, I'll be happy to make one. PM me with your info, and I'll get one to U.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 03-18-2017   #4
Mr Blue
While you're at it, I need one too.
PM sent
Mr Blue is offline   Reply With Quote
Old 03-19-2017   #5
Billy Mild
Such a simple piece really, but Paul has them in stock. They are cheap and really help to complement a header install.
Looking for a ZR-1
1985 Yamaha RZ350-NOT STOCK
1971 Yamaha AT1-Middle of a restoration
Old 03-19-2017   #6
MuRCieLaGo
Installed OBX headers last year:
-You might want to change your o2 sensors while you're there.
-You will have to cut a nipple and weld it, on one of the headers (if you have a 90-91-92-93).
-You will need to hit a pipe with a hammer (on the headers) on the driver's side so that it clears the steering shaft.
MuRCieLaGo is offline   Reply With Quote
Old 03-20-2017   #7
Michael n David:
The "nipples" being referred to are part #SLE 30115 "O2 bungs" from Summit Racing. They are mounted laterally to the header collector, so that they are facing toward the side, and slightly upward (to be clear of road debris you might run over.
Also, you'll need a couple of plugs to fill the old O2 holes on top of the collectors. ( I welded them in at the same time I welded in the bungs.)
90 #1202
Sans secondaries
Old 03-20-2017   #8
LGNDLT5
LGNDLT5's Avatar
[Hi Paul. I'll also need one for a SW header install. Can you make one more of those and how much, pay pal? etc. John R Sullivan 847-275-4841 LGNDLT5
LGNDLT5 is offline   Reply With Quote
Old 03-20-2017   #9
Mr Blue
Is it necessary to change the O2 sensor location? if so, are they angled inside or outside?
