Old 03-13-2017   #1
billschroeder5842
billschroeder5842's Avatar
Default How do I know the FX3 works?
Its the middle of March so I'm overdue for a stupid question...
How do I know that the FX3 suspension is ACTUALLY working?
Is this just a seat of the pants thing? I just drive about with the dial set to "Sport" because... well I just do.
Is there a way to check the system?
Also, if there is an issue, is there a default mode that the suspension goes into?
BTW... I just have a blast driving the car--- I have no desire to track or race but definitely occasional "spirited driving"
Bill Schroeder
Texas Proud!
1991 Corvette ZR1 #1388
Old 03-13-2017   #2
Billy Mild
Default Re: How do I know the FX3 works?
Go from Tour to Performance mode. You should feel a really big difference in ride comfort at low speeds. Tour feels floaty, Sport is a little firmer, Performance is very stiff.
Looking for a ZR-1
1985 Yamaha RZ350-NOT STOCK
1971 Yamaha AT1-Middle of a restoration
Old 03-13-2017   #3
Vette73
If you aske me it rides hard in every setting......But yes, there is a big difference between touring and performance.....I live in NY, it's always in tour....
Vette73 is offline   Reply With Quote
Old 03-13-2017   #4
billschroeder5842
So, it really is a "seat of the pants" thing? No way to "prove" the system is working? I'm thinking the dashboard diagnostic system?
Since I'm a FREAK about dash noise, I might switch to tour and see if my nerves calm.
Bill Schroeder
Texas Proud!
Old 03-13-2017   #5
ghlkal
ghlkal's Avatar
This is a good question. I'd like to know the answer too.
I have a Tech 1, but I don't have the Mass Storage cartridge. Does anyone know if the Tech 1 can check out the FX3 system (with or without the mass storage cartridge)?
1990 ZR-1 #2180 Red/Black
Many of the usual mods for 460HP, tuned by Marc Haibeck
ZR-1 Net Registry Member #1548
Old 03-13-2017   #6
secondchance
Turn the ignition switch to on position without starting the engine. This will light up all warning lights above the radio. Check and see if "service selective ride control" light is lit up. If it lights up that confirms the warning light bulb was not removed or burnt out. Now, if the light turns off and stays off while driving, means the system is operating correct.
Old 03-13-2017   #7
Roadster
Roadster's Avatar
I will check that out for you tomorrow with my Tech 1, unless someone else knows the answer. I do have the Mass Storage cartridge which was updated up to 1996. I've only used the Tech 1 to check out the engine parameters, but nothing else. Just need to explore more!!!
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 03-13-2017   #8
Roadster
Roadster's Avatar
My system must be good, because it does exactly what you have said....
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 03-14-2017   #9
mike100
If you can't tell the difference, the shocks are probably a bit worn. find some dips in the road and drive over them at full firm and full soft at about 40 mph to try to feel it.
Old 03-14-2017   #10
mike100
The tech1 will only short the fx3 pin to put its little controller into diagnostic mode. This mode blinks the codes through the service ride control light. It will not stream data to the tech1 or any kind of serial port connected device. It is fairly basic.
