Old 03-13-2017   #1
Default Corvette L98 Modifications
90’ (#8550) Corvette (L98) Modifications
New SW Headers
New Magnaflow Exhaust
New TPiS Air pump delete kit with New Billet Aluminum Pullley
New Belt Tensioner Billet Aluminum Pulley
New 180 deg thermostat
New Chrome Water Pump
New Chrome Alternator
New Plug wires
New C4 Beam Plates
New Differential oil drain plug (drilled and tapped)
New Billet Aluminum oil cap
Existing Existing Aluminum Radiator
New Oil Pan and Gasket including New Milodon 18309 Oil Pump Pickup
Fluids Mobile 1 75W-90 Differential oil (limited slip)
Fluids Mobile 1 10W-30 synthetic Engine oil
Fluids Castrol TWS 10W-60 Transmission oil
Eliminated Water Pump Frisbee and added Aluminum Water Pump Pulley
Eliminated Air Induction system
Eliminated CATS
Eliminated EGR
Doc Don's Bose
Modified Oil Cooler Use NAPA 8020 and 9808 hoses cut to length
L98 Oil Cooler Housing Modifications for Headers
Modified Marc Haibeck Chips
87 octane calibration (ARFPCL)
29 deg at WOT.
Enabled manual transmission.
Both fans to go on at 195 and both off at 190 degs.
Added +5% at WOT fuel to support +20 hp from headers.
Disabled deceleration fuel cut off.
Disabled EGR.
Idle speed is OE at 600 rpm.
91 octane calibration (ARFPCL1)
29 deg + 4 deg = 33 deg at WOT.
Knock retard reduced by 50%.
Disabled EGR.
SW Headers and Magnaflow Exhaust
See 90’ (#8550) Corvette (L98) Modifications For Details
