Made up a balancer installation tool this evening out of 7/8" threaded rod.
Essential LT5 special tool that's getting hard to find these days. ![]() A little stouter construction than the 3/4" Kent-Moore issued piece. ![]()
![]() Join Date: May 2016
Nice!
![]() Join Date: Dec 2003
Like everything else you do Phil.... very nice!
I gotta get me a small engine lathe & Bridgeport mill. Sent from my iPhone using ZR-1 Net Registry
![]() Join Date: Nov 2016
Would you produce one on request, Phil?
I might need one if I suddenly one day felt like replacing the balancer. Are they prone to wear? By the way, a google picture search on Prone to wear gives a lot more interesting result than one might imagine.
- '90 ZR-1 Last edited by S.hafsmo; 03-11-2017 at 03:45 PM. |
If there is sufficient demand I can do a batch of these.
Please post up if you are interested so I can figure out how much material will be needed and a unit price.
![]() Join Date: Jan 2006
Phil,
I'm in if you go forward. Have an extra crank locator/pin tool? Ted |
I'm in for one. I see Jerry has some harmonic balancers in store, so I'd might as well ad it to my to-do list.
- '90 ZR-1 Last edited by S.hafsmo; 03-12-2017 at 11:01 AM. |
#9 |
Ted,
IMO the Kent-Moore crank locator tool has too much slop in it for achieving accurate cam timing using the pinning method. So I made this tool which locates the crank more precisely and is just as easy to work with: ![]()
Phil Wasinger 1994 Torch Red ZR-1 WAZOO Member George Braml Intake Last edited by Jagdpanzer; 03-12-2017 at 11:42 AM. |
#10 |
Phil I'll take one of the balancer tools. You're stuff is really nicely done.
