Old 03-01-2017   #1
Dds1990
Default Spark removal
Wanting to change the spark plugs in 1990 #0106. I have no idea when or if they have been changed and if anti seize was used. It has 31k on it. Should motor be warm or cold? Any tips or suggestions would be great....
Dds1990 is offline   Reply With Quote
Old 03-01-2017   #2
Default Re: Spark removal
I have always done it cold without a problem... GC
Old 03-01-2017   #3
Dds1990
Thank GC..
Old 03-01-2017   #4
Kevin
Kevin's Avatar
never had an issue cold, but be prepaired for some qusi MacGyver engineering to get the back ps plug out
Old 03-01-2017   #5
Hib Halverson
No "MacGyver Engineering"?
Nah.
All you need is the following tools:
⅜-drive, ⅝-in plug socket with integral u-joint
one-inch extension
⅜-drive u-joint
long ⅜-drive extension.
Put all those together and you can easily remove plugs from #6 and #8 cylinders.
When I needed to change plugs, I used that tool stack for the entire 20 years I owned Barney.
Hib Halverson
Technical Writer
former owner 95 VIN 0140
current owner 19 VIN 1878
Old 03-01-2017   #6
Roadster
Roadster's Avatar
Just ordered one on the bay, inexpensive.....thanks for the tip....
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 03-01-2017   #7
ssrszz4
I used a regular socked and two swivels maybe a little harder but it worked.
ssrszz4 is offline   Reply With Quote
Old 03-01-2017   #8
tomcat
tomcat's Avatar
Hello, I bought my ZR1 in 2005. I change my Spark plugs 2006.
It was very easy, change them cold.
Manfred E.........
91 #906
tomcat is offline   Reply With Quote
Old 03-02-2017   #9
Dds1990
Thanks Fellas the help here is amazing as usual.
Old 03-02-2017   #10
Nah.
one-inch extension
⅜-drive u-joint
Exactly!
From there one graduates to removing those #%@@$^^ radiator hose spring clamps (w/o having purchased a special tool). OR, removing / reinstalling the C-beam nuts (especially if you have fat fingers), OR the real PIA - removing the stock exhaust heat shields, in preparation to install headers... Any one of these make you say "bad words" you'd rather nobody else might hear!
