Old 02-23-2017   #1
TealZR1
Default A Good Week with the ZR1
  • I am now a member of the Pulling the Plenum Club with the help of Marc's plenum video on the how-to of this task. Fixed the vacuum leak causing a high idle with the with connection of the famous emissions tube that tends to blow off under the plenum. Easier than it looks for you novices out there.
  • Also, had a local repair shop perform a roadforce balance to correct a steering wheeling vibration at speeds about 60mph. Now 750 rpm from 1200rpm.
  • Installed Marc's chip to improve several variables in the performance of my 91.More HP and No more using the valet key!
Now ready to enjoy Atlanta's upcoming Springtime and Caffeine and Octane shows with Velocity Channel filming! Got a brief look on first show!
TealZR1 is offline   Reply With Quote
Old 02-23-2017   #2
RussMcB
Default Re: A Good Week with the ZR1
Sounds like a satisfying week. Congratulations. I, too have benefited from Marc's contributions to the ZR-1 community. We're lucky to have him.
There's a slight chance I might see you at C&O, but I usually hear about them the day after they happen.
Old 04-25-2017   #3
Tripler
Tripler's Avatar
Good to hear . I am sure eventually I will have to do a plenum pull . No doubt Marc is an awesome bennifit to the group ... I also have his chip and it really does make the car run much better .
Enjoy your ZR-1 !!!
Sent from my LG-H831 using ZR-1 Net Registry mobile app
Tripler is offline   Reply With Quote
Old 04-25-2017   #4
billschroeder5842
billschroeder5842's Avatar
Originally Posted by TealZR1 View Post
[LIST][*]Installed Marc's chip to improve several variables in the performance of my 91.More HP and No more using the valet key!
Good job on the chip- it makes a difference
I too have a '91 and in my discussions with Marc (while ordering my chip) he said to consider swapping out the resonator for a much lower restriction one.
The earlier resonators are smaller in diameter and will choke pretty hard on the exhaust. I left my stock mufflers as I like the tip and apparently MArc says they flow pretty well.
Good work!
Bill Schroeder
Texas Proud!
1991 Corvette ZR1 #1388
[SIGPIC][/SIGPIC]
Old 04-25-2017   #5
George45
What was the source of the new resonator?
Sent from my SM-T817V using ZR-1 Net Registry mobile app
George45 is offline   Reply With Quote
