![]() Join Date: Nov 2016
I need to order radiator for my 91 and would like recommendations.
Now, I just drive the car- I dont race, the engine is not modified and I really dont get on it all that often (okay, I lied on that one). I need something reasonable and solid. I know there are many choices and I see prices run the gamut. While money is not a huge factor, I don't want to spend 600 when 300 will do. My primary decider will be fitment ease (lining up and using factory connections with no modifications) and overall durability for a spirited daily driver Also, from my research, I note that the L98 and LT5 share the radiator but mine does not have the transmission coolant lines bung holes that I keep seeing in the photos? Plus is there a HUGE difference in the all aluminum vs the plastic and aluminum? My plastic/aluminum lasted for 26 years.... I'll order later today or tomorrow for Friday deliver and install (hopefully) Thanks!
Bill Schroeder Texas Proud! 1991 Corvette ZR1 #1388 2015 Challenger Scat Pack Shaker ![]() |
#2 | ||
![]() ![]() ![]() Join Date: May 2007
Bill for these reasons just buy a factory GM or OEM Replacement. The last one lasted 26 years and provided adequate cooling for the car. You really only need to upsize the radiator if you plan on performance modding the car. Overtime the plastic ends tend to swell with age.. You wont get that with an all aluminum radiator.
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director ![]() 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 01-30-2017 at 08:51 AM. |
#3 | |
Should I get concerned that the replacements that I've seen have the automatic transmission bung hole? I realize they get covered by the shroud so its not an estetic thing but a fitment issue. So, will "any" OEM spec L98/LT5 '91 radiator do the job?
#4 | |
Roger that- thank you Sir!
![]() Join Date: Apr 2007
One day left to get in on the Dewitt annual 15% off sale. http://www.corvetteforum.com/forums/...post1593940565
Go with their 1129090m single row. Around $300 with the discount
#8 | ||
I have Ron Davis (expensive but the best) and Fluidyne in all Zs. Also run with 180 deg Thermostats in all Zs except 195 deg Thermostat in L98s. I think I also have a Dewitt in one Z which was previously installed. C4 Corvette Aluminum Radiators Quote:
Install all Screw Clamps such that the screws/nuts are accessible after installation of the fans and Radiator. I use a bit of Permatex on ALL Radiator Hoses/Fittings
Left Clickable links ![]() -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 01-30-2017 at 01:09 PM. |
#9 | |
