01-28-2017 | #1 |
oil pressure sensor socket
Where can I get a socket that fits our oil pressure sensor. I see it's 1 3/16 inch but all the sockets I find are to shallow. It appears it needs to be at least 3 1/4 inch deep.
Gary 90-1572 |
01-28-2017 | #2 |
Re: oil pressure sensor socket
I picked one up from O'reillys this summer for around $7, it was labeled as an oil pressure sensor socket.
1991 ZR-1 #1438 Black/Black & Red |
01-28-2017 | #3 |
You can also try Lisle #13250 found on ebay. Size is 1 1/16", and fits switches up to 2 5/8" long. Just tried mine on the 94 and it fits perfect.
01-28-2017 | #4 |
The oil pressure sending unit on my 90 is 1 3/16. It is 3 1/4 inch tall. The sockets at Advance.O'reilly Napa and Harbor freight are all 2 5/8 or 2 3/4 deep.
Gary 90-1572 |
01-28-2017 | #5 |
KPW I'm trying your way of changing out the alternator w/o removal of throttle body. I've got everything unbolted except the oil pressure sensor and battery cable on back of alternator.
Gary 90-1572 |
01-28-2017 | #6 |
I think the size changed in 91....
01-28-2017 | #7 |
01-28-2017 | #8 |
Thanks roadster. I just ordered it. It arrives on Feb 6. I thought I had everything I needed until that socket turned out to be extra special.
Gary 90-1572 |
01-28-2017 | #9 |
No problem Gary, I may be doing the samething with my replacement alternator that is on the car, as the fan blade is rubbing, and no matter what I do about the blade hitting the housing, it doesn't work, or only works for a short time and then the noise is back.....lol
So keep us posted, I may start on it tomorrow......
Tom 1994 ZR-1 #009 "captured test fleet car" 1974 LS4 454 Vert 1974 L-82 355 Vert. 1982 L83 CFI...now a retired "dd"....Sold WAZOO Member Last edited by Roadster; 01-28-2017 at 04:40 PM. |
01-28-2017 | #10 | |
