Fighting a high idle around 1100 when hot. Troubleshooting now replaced PCV Valve rubber and tightened up all hoses.
Saw where an easy troubleshoot would be to change the IAC Valve on top of plenum possible problem. Is this as easy as it looks? Could it be the issue? Thanks to all in advance. |
#2 | |
![]() Join Date: Mar 2014
![]() Join Date: Feb 2011
It is probably one of the large vacuum lines under the plenum...the gas tanke purge system lines- they sometimes pop off if there is a backfire or some similar event.
Thanks roadster and Mike 100 for the quick reply. Those are my final two options. Will look at the IAC valve this weekend and pull the Plenum down the road if needed
it has been talked about before (do a search), but if you take off the air duct and block the throttle body with a stiff piece of cardboard or a phone book (anybody still have one of those?) the engine should stall. if it still runs, you can clearly locate the vacuum leak noise under the plenum.
My hunting and high idle was caused by the large vacuum line under the upper plenum. I zip tied the hose to the plenum nipple.
Sent from my Nexus 6P using ZR-1 Net Registry mobile app
1991 White ZRJuan #1616 Mileage: 56K Sept-14 -- 113k May-18!!! God Damn I Love This Car! |
I stand corrected, just took the 94 out for a ride, and close to the same thing on the idle. Sometimes coming to a stop idling at 1000-1100 r's. Other times around 800-900r's. So it looks like cleaning the IAC really did not have any effect on the idle, at least for me.....
Tom 1994 ZR-1 #009 "captured test fleet car" 1974 LS4 454 Vert 1974 L-82 355 Vert. 1982 L83 CFI...now a retired "dd"....Sold WAZOO Member Last edited by Roadster; 01-27-2017 at 02:00 PM. |
#8 | |
![]() Join Date: Aug 2006
#9 |
Copy that....will do.....
#10 |
