Old 01-25-2017   #1
Dds1990
Default 1990 Bose Relay Location
Moving onto next winter project on BR 1990 #0106. So far I have replaced the Clutch master and slave cylinders thanks to Jim from Power Torque Systems, what a great guy. Ventured under the dash replaced the CHMBL switch, works now. Cleaned and remounted both air bag sensors and actually got that pita infl/seatbelt light to reset after a few tries. The Bose system is next. Radio will turn on but nothing is heard from speakers. Wanted to check the Bose relay but do not know exactly where its at before I start pulling speakers, as usual any help would be greatly appreciated.
Dds1990 is offline   Reply With Quote
Old 01-25-2017   #2
billschroeder5842
billschroeder5842's Avatar
Default Re: 1990 Bose Relay Location
9 times out of ten your amps are defective if you have a Bose Gold.
However, if you get lucky (like me) your radio ECM is shot and needs replacing as well.
In my case I replaced the ECM and 4 amps. I now have an $800 radio!
Bill Schroeder
Texas Proud!
1991 Corvette ZR1 #1388
[SIGPIC][/SIGPIC]
Old 01-25-2017   #3
WVZR-1
Should've done the Bose relay while you were under the left side of the dash doing the CHMSL switch. You do now know the "how to" though. Get familiar with the 8A-201 section of your FSM. There's many answers there. One page after the wiring diagram for "most" components/circuits there a reference to 8A-201-X for images and also 8A-202-X for potential connector identification.
Old 01-25-2017   #4
Dds1990
I just have the standard FSM and could not get the pic to download....I venture under there again if necessary just need to know where and what to look for.....im 6'1' 270...its nice under there..lol
Old 01-25-2017   #5
Dds1990
Bill I hope Im not lucky like you...
Old 01-25-2017   #6
Dds1990
WVZR1 Thanks got the pic to download....Ive got a electronics guy Im going to take a rear speaker to him and see what he can do. Although Im getting pretty good at taking the drivers seat out and crawling under there..getting out is the problem.
