Appears to be a leak at my front PCV valve (very loose grommet) causing a high idle. I want to slip a small piece of vinyl tubing on the pcv nipples and than reinstall the grommet in hopes this will seal the grommet to the pcv. My question is what is the best way to remove the existing pvc valve. Any tricks to doing this? Very tight quarters. Thanks for your help in advance
#2 | |
![]() Join Date: Dec 2003
Replace all of your 25 year old dried up stuff from Jerry with silicone, these are just old cars that need help causing your idle issue
#4 | |
![]() Jerry's Dual PCV Valve Connector Jerry's Dual PCV Valve Connector Hose Jerry's Dual PCV Valve Connector Grommet ![]() ![]() ![]() New PCV Connections. Installation/Relocation of Plug Wires and New Spark Plugs
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 01-13-2017 at 10:57 PM. |
