Old 01-08-2017   #1
S.hafsmo
S.hafsmo's Avatar
Default Secondaries actuator solenoid valve
Can one still acquire the solenoid for the secondaries anywhere? Or are the included in any of the hose kits?
- '90 ZR-1
S.hafsmo is offline   Reply With Quote
Old 01-08-2017   #2
secondchance
Default Re: Secondaries actuator solenoid valve
Looks like Jerry's gasket has them.
http://www.jerrysgaskets.com/actuato...sed-90-95-2d1/
Woops! Is says out of stock.
Bit expensive but White racing products.
http://www.ebay.com/itm/90-95-Corvet...RX1rup&vxp=mtr
Old 01-08-2017   #3
ssrszz4
Looks like the ones from Jerry's are used
ssrszz4 is offline   Reply With Quote
Old 01-08-2017   #4
S.hafsmo
S.hafsmo's Avatar
Appreciate the links, gentlemen, but those are the actuators, and I'm looking for the solenoid.
- '90 ZR-1
Old 01-08-2017   #5
Jagdpanzer
Jagdpanzer's Avatar
Here in a previous post on the same subject:
http://www.zr1.net/forum/showthread.php?t=11619
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 01-08-2017   #6
S.hafsmo
S.hafsmo's Avatar
Thanks! Just what I was looking for.
- '90 ZR-1
Old 01-10-2017   #7
There are 2 parts,an early and late. The early valve has the small foam filter and the later design has the slip on filter that slips on a nipple on the valve.
Old 01-11-2017   #8
S.hafsmo
S.hafsmo's Avatar
Do you know if the later style will fit? And if, does anyone still sell it?
- '90 ZR-1
Old 01-11-2017   #9
Either one will work.
Also, A couple of years ago, I bought 20 of the AC Delco # 214-358 / GM# 1997212 solenoid valve to convert & use for replacements, as per the link provided in post #5.
Every one of them leaked vacuum when tested. The tests were validated against a new OE valve which held vacuum. Needless to say, I abandoned the project until I could find the time to see about making a repair kit to "overhaul" the OE valve. I have not encountered an OE valve that had a faulty solenoid actuator, just leaky.
Old 01-12-2017   #10
S.hafsmo
S.hafsmo's Avatar
Well that's a bit disappointing. I was just about to buy one of those. Surely there must be solenoids one could modify for the purpose? I assume these are molded shut/not serviceable?
- '90 ZR-1
