Old 01-02-2017   #1
BigIke
Default Vacuum pump
If my secondaries are wired open, and eliminated in the tune, do I need my vacuum pump?
Sent from my Nexus 6P using ZR-1 Net Registry mobile app
1991 White ZRJuan #1616
Mileage: 56K Sept-14 -- 113k May-18!!!
God Damn I Love This Car!
Old 01-02-2017   #2
Default Re: Vacuum pump
NO........you do NOT need your vacuum pump
You can put it on the shelf or just disconnect the electrical as you may want to go back to Secondaries as a future option since you "wired" the secondaries rather than eliminated them
LT5 Eliminated Systems
LT5 Added Systems
Old 01-02-2017   #3
BigIke
Thanks buddy!
Old 01-02-2017   #4
Originally Posted by BigIke View Post
Thanks buddy!
Just remember to block the Drivers Side Plenum Vacuum Source when you disconnect the vacuum pump to assure there is no open vacuum line to Plenum.
There is an arrow to that Plenum Vacuum between the middle two runners of the Plenum on the Drivers side below. I installed a threaded plug but you can just place a rubber cap over the nipple as you like or even Silicon seal the nipple which silicon seal is removable later.
Old 01-03-2017   #5
Or u could use plenum vacuum to operate flapper valves for ur exhaust.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
