Old 12-15-2016   #1
RichS
Default Winter mods...
Since the white stuff is piling up around us, I figured it's time to start the winter mods soon. I'm going to pull the motor to clean everything and port the heads, intake, injector housings, do the coolant bypass, headers, and a different catback to start. I've been reading a ton of posts but didn't see about the gaskets. Do you buy the gaskets oversized already or do you have to trim them? Is the throttle something to send out to have oversized as well? Most likely going to order the top end overhaul from Jerry's in a few days. I'd love to do the cams and was thinking about them since it's out but hard to get a idea on cost with the 4 cams and lifters. I've seen some regrinds for the $14-1600 range. What options are out there? Don't want to go to crazy yet..... maybe stroke it in a few years. I love the 397 I built in the GS. Thanks!!
RichS is offline   Reply With Quote
Old 12-15-2016   #2
Default Re: Winter mods...
Our gaskets have increased ports diameters which will eliminate the need for trimming if the port work matches the gaskets. It is recommended to use the gasket as a template.
Plenum Gaskets: read about port size
http://www.jerrysgaskets.com/gasket-...64-90-95-11d3/
Injector Housing Gaskets :read about port size
http://www.jerrysgaskets.com/gasket-...ng-90-95-11d4/
Depending on the port work style performed, if the bifurcation between the ports is removed, its a simple matter to use a pair of scissors to cut out the gasket center section with a straight cut tangent to the port o.d. of both ports.
Old 12-15-2016   #3
If you are interested in cams, I would suggest:
1. Drive a ZR with that mod
2. Talk to Pete.
Old 12-15-2016   #4
Vette73
Actually drove a 95 a few weeks ago with ported top end,intake cams and stock heads and it was impressive, even with the stock heads...
Vette73 is offline   Reply With Quote
Old 12-15-2016   #5
Kevin
Kevin's Avatar
I've driven a fully ported 94-95 with headers gears and cams. It RIPPED!
Old 12-15-2016   #6
Kevin
Kevin's Avatar
If you want to sell the pe exhaust let me know. I maybe interested
Old 12-15-2016   #7
Nice combo made even better w ported heads. ~ 435rwhp
Old 12-15-2016   #8
RichS
I have it listed in the for sale area for $450
Old 12-15-2016   #9
Kevin
Kevin's Avatar
Guess I need to read that section more often!
Old 12-18-2016   #10
RichS
Started to pull it apart today. Pulled the trans, clutch, cats, most of the top end. Found the vacuum line was disconnected and capped for the fuel pressure regulator by po? All the lines under the intake look good, Few more than the LT4 Need to start the since ya list.
