Old 12-06-2016   #1
90_ZR1
Default New ZR1 Owner With Plenum Vacuum Question
Bought my first ZR1 a few weeks ago and am trying to get it running right.
I pulled the plenum and replaced the injectors and coils. I almost have it back together, but don't know where the plug on the rear connects (points to firewall).
Is there a hose above the bell housing I can't see?
I have a pic, but am having issues uploading it.
90_ZR1 is offline   Reply With Quote
Old 12-06-2016   #2
Default Re: New ZR1 Owner With Plenum Vacuum Question
You don't say if you are talking about an electrical or vacuum connector.
See if this answers your question.
Old 12-06-2016   #3
90_ZR1
Thsnks for the pic. It is the vacuum line that goes to the MAP sensor. It sure is frustrating when you methodically remove parts, then something disappears when you go to reassemble. Not sure what happened to the hose.
Old 12-06-2016   #4
BigJohn
BigJohn's Avatar
Your hose probably ran off with my socks!
