Old 12-05-2016   #1
Default Spare tires options for big brakes.
What kind of spare options for a car with a 13.5 front rotor with C4 calipers. Thanks.
Old 12-05-2016   #2
secondchance
Default Re: Spare tires options for big brakes.
Early 2004-6 Pontiac GTO, I believe, offered 17" spares. I'm not sure it would clear 13.5" rotor.
I carry Cadillac CTS-V, 18" spare wheel. These certainly will fit 13.5" rotor.
Old 12-05-2016   #3
With C6 Z06 brakes, I face this issue as well. Somebody makes a spare fir the Z06 crowd but they want $900 for it. May look for a C6 wheel/tire.
Does the CTSV have any offset issue. I believe the GTO spare requires a spacer.
I pretty much have settled on the Continental kit w pump and sealant. No good solution when u run staggered wheel sizes.
Old 12-05-2016   #4
BigJohn
BigJohn's Avatar
Purchase another front wheel and tire it will fit in the back carrier.
Try it with the wheel you have!
Old 12-05-2016   #5
secondchance
Any spare, as long as it clears brake caliper and rotor, is acceptable. Spare tire is a temporary solution. CTS-V spare works. Offset issue? No issue when discussing spare tire, in my opinion.
Old 12-07-2016   #6
mike100
the gto spare doesn't need a spacer, but it does need .030 or so ground out of the center hub hole to fit a c4/c5 hub. technically the bolt pattern is a tad different, but it fits fine. I drove mine up to 70 mph etc- no issues.
Old 12-07-2016   #7
secondchance
Same with CTS-V spare. Center hub hole had to be bored out lightly.
Old 12-09-2016   #8
I think a CTS-V spare is in the works. Thanks for all the info.
