Old 12-03-2016   #1
BigIke
Default C6 GS Wheels - INSTALLED!!! :)
Well I got the wheels on and set up correctly. Hopefully I'm not double posting... 18mm spacer on the driver side. 23mm spacer on the passenger side, I could probably install a 25mm and it would match the driver side perfectly.
Old 12-03-2016   #2
Default Re: C6 GS Wheels - INSTALLED!!! :)
Needs big brakes now.
Old 12-03-2016   #3
Roadster
Roadster's Avatar
Nice wheels, looking good!!!
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 12-04-2016   #4
JThomas
JThomas's Avatar
Pardon my ignorance, but why wouldn't you have the same size spacer on both sides?
Joe Thomas
Corvette Club of Michigan
NCRS-Michigan Chapter Member
NCM Master Ambassador
Former NCM Board Member
1991 ZR-1 Melon Copper Metallic/Black
1992 ZR-1 Bright Red/Black (Sold)
1995 ZR-1 Bright Aqua/Gray (Sold)
2012 ZR1 Super Sonic Blue / Dark Titanium
JThomas is offline   Reply With Quote
Old 12-04-2016   #5
Are u using stock rotors up front? If so, how far outboard of your fenders are the tires? Until I installed front Z06 brakes and rotors on mine, which made the C6 40mm offset work in place of the stock 56mm.
Also, did th extra 1/5" in the rear spacer make that much difference visually? I'm using 18mm both sides.
Joe, the passenger side is slightly inboard compared to the driver's side.
Old 12-04-2016   #6
Vette73
I like the look.....C6 Z06 wheels and C6 GS wheels give the Z def more of a muscular stance......How do they compare as far as weight wise to the stock set up? Any idea? Nice shop by the way......
Vette73 is offline   Reply With Quote
Old 12-04-2016   #7
I think the weight diff is negligible.
Here's a shot of the 1st Gen C6 Z06 wheels. C6 Z06 brakes are installed in this pic. 18/19 split gives the car a "rake" to it.
Old 12-04-2016   #8
325 tires are about 2lbs more than 315s.....EMTs 4 lbs more
Z06 Stock wheel is 26.5lbs vs stock A-Mold at 21.5lbs; appears C6 GS wheels also weigh in at 26.5 pounds
Aftermarket Amolds can be much heavier than that stocks...26+lbs
Old 12-04-2016   #9
Thanks Lee. Is that for both front and rear?
I had 325 Nitto Invos on the rears but now have 345 Michelin SS. The weight differential is negligible between those tires. In fact, the Michs' were a bit lighter.
Old 12-04-2016   #10
Tire Rack lists the tire weight in the "Specs" tab for the tire....that's just the rears
