![]() Join Date: Nov 2016
So I'm finding all sorts of do-dads on my ZR1.
I noticed that my factory exhaust only has the outside tail pipe that "works" and the inside seems to be decorative? Is that right? Anyone do anything different other than swap out the system? Thanks!
Bill Schroeder Texas Proud! 1991 Corvette ZR1 #1388 2015 Challenger Scat Pack Shaker [SIGPIC][/SIGPIC] |
My 91 ZR-1 works off long tube stainless headers and true duals. Late model Vettes druel when I pull up at events!
![]() Join Date: Sep 2012
Not uncommon. I know my Corsa's are like that. Although, if you have the original exhaust then you should have one wide rectangular tip on each side not two round tips per side.
![]() Join Date: Nov 2011
Early models had two square per side. Well, square like the tail lights.
Yep, mine is like that.
Only one outlet functions per muffler.
![]() Join Date: May 2010
You show off.......lol. I love that mod.
Craig "ZR-1 NO KA 'OI" "ZR-1 ICHIBAN" 1995 #228 Black/Black with Dunn Heads ZR-1 owner since September 2003 ZR-1 Net Registry Founding Member #0074 NCM Lifetime Member #2048 ![]() |
#9 |
#10 | |
![]() Join Date: Apr 2007
The chamber is called a Helmholtz resonator and it engineered to be a specific shape and volume to cancel out one of the two main natural frequencies that our engines generate that create the intense resonance or "droning" under light to moderate load at 1800 and 3400 rpms that you have heard many with certain aftermarket exhaust systems complain about. The exact shape and size allow for sound waves of a specific frequency to enter the chamber, bounce around and cancel each other out. The center resonator also has such a Helmholtz resonator for the 3400 rpm frequency of 230 Hz; the mufflers deal with the 1800 rpm one of 120 Hz. Sometime people drill out the dummy tailpipe thinking they will get better performance and a better sound. They are rewarded with the same performance and a loud droning at 1800 rpm. Bad idea. Corsa also uses Helmholtz resonators, and I suspect some newer ones of other makes now do too. Most of my research on this was done in the 90s; I am sure that several manufacturers hove found solutions to this problem. At the time, only the stock and Corsa systems tamed the resonance. Hope that helps--Bob
2016 Long Beach Red Z06 #10281 "POPS Z" 1995 Polo Green #409 "WARP TEN"--Haibeck 350/510 package, 4.10s, Hurst, Stock Exhaust with QTP Cutouts --Sold but still running strong 1993 Quasar Blue #161 "HIL KING" --Sold but still running strong, now with more than 120,000 miles 1967 Marlboro Maroon/Saddle Corvette Coupe 300 hp/4-spd --Sold a long time ago ZR-1 Net Registry Founding Member #95 NCM Lifetime Member Favorite Quote--Attributed to Mickey Thompson: "Too Much Horsepower is Almost Enough" Last edited by WARP TEN; 12-03-2016 at 12:58 PM. |
