11-24-2016 | #1 |
Soon time to replace coolant hose,any and all tips welcome.
I'm going to tackle this job here pretty soon on my 91 and I'm looking for any and all tips tips to help me out. I'm working in a one car garage so I want it to go as smoothly as possible. Any obstacles to look for,will have among the top shroud off help ease any grief that might pop up? I've got a set of the clamp pliers.If anyone can think of the biggest hassles to the smallest details I'm all ears. Thanks to all for any info.
11-25-2016 | #2 |
Re: Soon time to replace coolant hose,any and all tips welcome.
With the shroud off, remove the cooling fans & radiator. Only with the radiator removed, can it be cleaned properly of all the debris it's collected during its life.
Makes access to the hoses easier & will increase cooling efficiency.
11-25-2016 | #3 |
Hey Jeff,
Did you decide on silicone hoses? If so, definitely get the special clamps that don't cut into the hoses. I have to do this soon too and will replace with Fluidyne radiator and SRP thermostat while I'm at it. No cursing allowed (ha, ha...that guaranteed).
11-25-2016 | #4 |
When you remove the cross over tube make sure you replace the new hoses in the same orientation (angles) on the tube as the old hoses. As you pull one make you immediately replace the hose exactly as the one you just pulled off. Spray penetrating oil on the backside of the holes for the bolts that mate the thermostat cover to the housing. You well need to remove it to get that short hose on. No way around that. If you don't spray the oil in the backside of the screw hole you might snap the bolts. I suggest replacing the hoses with silicone and make sure you get stainless clamps. I just did this project on my 90 I bought my no logo hoses from Jerry along with the clamps.
11-26-2016 | #5 |
I have not removed radiator or cowling to do that job but did have trouble removing one of those original hose clamps on the main Water Pump bottom hose. Removing Original Coolant Hose Clamps TIPS
Also.....those bolts in the Thermostat Housing can be broken off and if tight I would use a little heat from a torch on thermostat housing. Also....MAKE SURE you get that New Thermostat Gasket seated using a thin blade to keep it in place as you put the two halves of the thermostat housing together. You have to hold the two halves of the Housing together as you tighten the bolts as there is pressure from the thermostat to push the two halves apart. Install that short Hose between thermostat Housing and Radiator before you bolt the Thermostat Housing to the Frame. Also. ...I use a thin coat of Permatex on all pipes and inside hose ends when replacing hoses. Also......I use Jerrys Rounded Clamps on ALL Hoses and use I think a 7mm socket on those hose clamps to tighten. Also......Set the clamp screw so it is easily reached from bottom or top with a 1/4 socket wrench and various extensions. Also......I use a 180 deg Thermostat with the two slots in the bottom (from Marc) and I think Jerry has the correct thermostat also http://www.jerrysgaskets.com/thermos...ant-90-95-4d2/ Also.......when you replace coolant........I use the Blow technique to make sure the Air is Out of the Water Pump Area. See Getting the Air Out Simplified TIPS for the Simplified Discussion regarding The Air Locked Water Pump. Oh....and getting those original hoses off may require you take a razor blade and cut lengthwise where the hose fits on the various pipes. That is prolly the Biggest issue getting the original hoses off right up there with getting the New Thermostat gasket in place properly.
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 11-26-2016 at 07:56 PM. |
11-26-2016 | #6 |
I used Jerry's silicon hoses with heat shrink clamps, real clean installation (looks wise, install was a bitch).
11-26-2016 | #7 | |
Also I suggest drilling 3 1/8 inch holes in the rim of the thermostat while you are there. Have fun GC
11-26-2016 | #8 |
And I thought it only took ME 3 hrs. Getting those dorman style hose clamps was a real PITA even with the right tool.
11-26-2016 | #9 | |
What do you think about the one used in this video? https://www.youtube.com/watch?v=quF4UYv6-Pc
11-26-2016 | #10 |
This thread describes what I went through to remove one of those stock hose clamps and a very similar tool (identified by Scrrem) to what Craig describes.
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 11-26-2016 at 07:54 PM. |
