Old 11-22-2016   #1
5ABI VT
Question Solid Motor mounts? Any options? Any interest?
Wondering if anyone can make them or has made them in the past? IF there are none I wanted to ask if anyone has any old stockers I could use to have a solid set fabricated ?
Old 11-22-2016   #2
BigJohn
BigJohn's Avatar
Default Re: Solid Motor mounts? Any options? Any interest?
Do you really want to break something?
Old 11-22-2016   #3
5ABI VT
What would be breaking ?
Old 11-22-2016   #4
BigJohn
BigJohn's Avatar
Vibration ,Engine block, Frame mount, bell housing, transmission housing and transmission mount.
But you can do anything you want!
Old 11-22-2016   #5
mike100
What would you gain from it? There's a ton of downsides.
Old 11-22-2016   #6
Jagdpanzer
Jagdpanzer's Avatar
Latest version of the stock mount is a good piece.
Fully captured if elastomer bond should fail.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 11-22-2016   #7
Billy Mild
Do motor mounts ever need to changed on these things? On other cars I have owned it isn't a common problem, but on my 944 they always need to be replaced due to age. If they aren't replaced then the car vibrates a lot at idle.
Looking for a ZR-1
1985 Yamaha RZ350-NOT STOCK
1971 Yamaha AT1-Middle of a restoration
Old 11-22-2016   #8
Jagdpanzer
Jagdpanzer's Avatar
I'm sure most C4 Zs out there are with their original
factory motor mounts.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 11-23-2016   #9
Billy Mild
From previous experience urethane mounts are best of both worlds. Minimal movement but yet not all the NVH. Solid mounts vibrate everything and in a car that already has a reputation for squeaks and rattles this just sounds like a complete nightmare.
JMHO
Sent from my Nexus 6P using ZR-1 Net Registry mobile app
Looking for a ZR-1
Old 11-23-2016   #10
5ABI VT
I was actually thinking more about a poly mount and not a solid metal mount. I did find a few websites that appear to make them for any application so it shouldnt be impossible. I isn't search enough to be sure if the engine to mount bracket is the same as the LT1 or if the mounts are the same but it appears one of the two are interchangeable.
As far as I see it a stiffer mount will take twist out of the c beam where it is connected to the rear end. I've been in a few cars with poly and they do vibrate some more but they also make the motor feel much more direct and responsive which I like. Worst case I can put them on my 93 LT1 car. With a .700+ lift solid roller cam and tight leave and 370s duration it will already vibrate so some poly mounts shouldn't be noticeable lol!
