![]() Join Date: Mar 2013
Because of the heat shields, it is very difficult to tell what condition they are in. That said, they are 27 years old and figured I would just replace them before they are no longer available. How is this done? I already have the car up in the air on jack stands fixing a bunch of other stuff and have the exhaust removed from the headers and the c-beam and propeller shaft are also removed.
1995 ZR1 #159 Ported,Corsa,4.10 Rear, Dual Disc RAM Clutch, Alum Flywheel, Haibeck Chip, ZFDoc Plates, Relocated Battery 400 rwhp 1992 ZR1 #280 Ported, Locked Secondary's, Flowmaster Exhaust, Haibeck Chip, 375rwhp 1996 Collectors LT4 (Stock) 1972 Convertible 434 Small Block 572 rwhp |
Interested to know as well. Does anyone make solid mounts ?
![]() Join Date: Apr 2007
GM part #10157980
![]() Join Date: Dec 2003
Here's a link with the procedure for replacing the Motor Mounts.
http://www.jerrysgaskets.com/mount-motor-used-90-95-3c/ See description for Mtr Mount at that link. Sent from my iPhone using ZR-1 Net Registry
Jerry Downey JERRYS LT5 GASKETS & PARTS http://www.jerrysgaskets.com 1994 ZR-1, Black/Black, Lingenfelter Aerobody, 416cu in, 3.91 gears, coil-over susp, Brembo brakes, etc. 2016 Black-Red, 3LT-Z51 Auto 8-speed. Last edited by A26B; 11-15-2016 at 07:40 PM. |
Thanks for the input, I was hoping the headers would not have to be removed. From what I can tell they look to be in good shape. No signs of leakage. I think I will leave them be for now.
