Old 11-04-2016   #1
32valvesftw
Default Sensor on Master Cylinder
There is a sensor with two wires going to it on my master cylinder, the wires are disconnected and it looks I may have broken the connection somehow. I drove the car the brakes feel fine and no warning lights are on, what does that sensor do? Low brake fluid warning perhaps?
Old 11-04-2016   #2
BigJohn
BigJohn's Avatar
Default Re: Sensor on Master Cylinder
Are your brake lights working?
Old 11-05-2016   #3
32valvesftw
Dunno I'll check
Old 11-05-2016   #4
32valvesftw
Its the differential pressure warning switch. The connection pulled out and the wire ends are stuck in the switch, so I need to replace the connector.
