Old 11-03-2016   #1
efnfast
Default New cams
New to me regrind cams just arrived. (Thanks Lee, did my check show up?).
No immediate plans to install them, but I'll try to keep this post up to date as things change. - Steve
Old 11-03-2016   #2
efnfast
Default Re: New cams
Lee, can you repost the spec's on the cams? It appears the original thread has been deleted and I don't have them.
Also, rumor has it I will need new lifters. What do I need for lifters?
Old 11-03-2016   #3
BigJohn
BigJohn's Avatar
Steve take them off the kitchen table!
Old 11-03-2016   #4
efnfast
Think the wife will be mad if the entire engine is broken down on the table and parts are soaking in the sink?
Old 11-03-2016   #5
Mystic ZR-1
Mystic ZR-1's Avatar
When the Bride's not looking,
the dishwasher makes a great parts
cleaner.
Old 11-03-2016   #6
Intake: 236 .425 Lift
Exhaust: 222 .415 Lift
Old 11-06-2016   #7
efnfast
Do I just need a new set of stock lifters? Or will I need something special?
Old 11-06-2016   #8
you need new stock lifters; builder should check clearances, etc
Old 11-06-2016   #9
efnfast
Sooooo, can I pre-order these if I find them on sale?
Are they all the same, or are there better sources/quality?
Old 11-06-2016   #10
Get Mellings Lifters from Jerry. You will need 32 Lifters Total.
Melling Lifters
NO.......All Lifters are NOT the same.
Tech Info - LT5 New Rebuild Issues (Lifters, Camshafts, and Valves)
