Old 11-02-2016   #1
Locobob
Default Fuel Pressure Testing
So I've been driving around with a fuel pressure gauge taped to my windshield trying to sort out some drivability issues. Here's what I'm seeing:
42psi at idle
Usually jumps up to about 47-48psi if I hit the throttle hard, but a couple of times it actually dipped a little first.
Drops to about 38psi briefly when I drop the throttle out rapidly after gunning it.
Around 40psi at light throttle cruise.
Anyone else do this and what did you see?
Also left block learn is higher than right, about 144 at idle vs. 128
Interestingly the car seems to be driving fairly well today, not noticing the issues I was having in the last weeks. It is very dry here today while it's been pouring down rain for the last few weeks, I wonder if that has anything to do with my rough running issues. Hmmm
Robert
Old 11-02-2016   #2
mike100
Default Re: Fuel Pressure Testing
does it hold 48 psi beyond 5500 rpm? 50-52 is what both pumps in tandem should achieve, but maybe allow for a fudge factor if your gauge isn't super accurate. In my case the pressure went up to spec (50+ psi) when you stepped on it and the secondaries were open, but since one pump was weak, it dropped to 45 psi by 6500 rpm.
