Old 10-29-2016   #1
QB93Z
QB93Z's Avatar
Default Renovations to the new home for ZR-1
I finally got time to repair the new to me garage that will house two ZR-1's
1990 Black ZR-1 - sold
1993 Quasar Blue ZR-1
1994 Competition Yellow ZR-1
1995 Dark Purple ZR-1
Maryland State Coordinator
Old 10-29-2016   #2
QB93Z
QB93Z's Avatar
Default Re: Renovations to the new home for ZR-1
The foundation had settled years ago, so I had to lift and support the roof and demolish half of the side wall.
Old 10-29-2016   #3
dredgeguy
dredgeguy's Avatar
Looks good Jim and glad the weather has worked out as well. Looks like it is getting close to a "break in the new garage party".
Charlie
__________
Dredgeguy
Dana 4:10 gears
Polished LT5 by Haibeck
Old 10-29-2016   #4
That happened to me in one of my homes. Lucky the house was new but they had to Tear out the entire garage slab while the garage was jacked to keep it from pulling it down.
Old 10-29-2016   #5
BigJohn
BigJohn's Avatar
With that much work you should raise the roof to make room for a lift.
Old 10-29-2016   #6
Roadster
Roadster's Avatar
I agree with Charlie.......
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 10-29-2016   #7
QB93Z
QB93Z's Avatar
That is a good idea, a lift would be nice. But the garage is not really in good enough shape to be worth the effort. There are several other areas where the foundation settled. There are very few plumb or level parts of the garage.
Old 10-29-2016   #8
diamond zr1
wow Jim/looks like a earth quake hit it/good luck with the rebuild/just added 20 by 40 to my shop/need areas to park my friends race car/you missed a great bbq/but with a project like that and winter setting in I understand how important to get project going/our weather was great and finally cooling down here/hope you saw the photos Mark posted of the weekend/Cheers/joe
diamond zr1 is offline   Reply With Quote
Old 10-31-2016   #9
QB93Z
QB93Z's Avatar
Here are a few more shots of the repair:
On the center column the 3 inch block is how much I raised the header to get the left opening level. The column on the right is all new construction. That side was raised about 4 inches:
Laying block. The jack columns and beam are supporting half the weight of the roof:
I still have to set the roof back down and adjust the garage doors. Then I can park a ZR-1.
Old 10-31-2016   #10
Jim are you doing this work? If so when is the battleship grey going to be employed ?
