![]() Join Date: Mar 2007
$80 OBO
These are new in the wrapper Plenum Insulator Kit Low profile (1/8" thick) phenolic insulator plates assist in plenum temperature reduction, while minimizing the chance of hood interference: plates,and fasteners. This requires plenum coolant block off Pics of Spacers listed here http://www.zr1products.com/#!products
LGAFF 90 #966-150K miles-sold 92 #234-sold 1987 Callaway TT #17 1991 ZR-1 #1359 Last edited by LGAFF; 10-24-2016 at 06:08 PM. |
These are 35.5mm port diameter
Best Offer
Im curious as to what color these are? Are they still made or is this something that has been discontinued? are these reuseable? sorry for all the questions ! Also if I may just ask as im not personally familiar with that site... do they still sell that thermostat ?
They are a brown color, reusable as far as I know
Not sure what SRPs inventory is or if they are selling
![]() Join Date: Apr 2016
Do these plates eliminate the need for gaskets?
Will let others comment, I would think they would still be needed, but might be incorrect
![]() Join Date: Dec 2003
![]() No, they do not replace/eliminate gaskets. In fact, two sets of Intake Plenum Gaskets are required when the spacer is used, one on each side. Spacers are reusable. The photo on SRP's website shows the Throttle Body Heat coolant port is open in the plates. Like our gaskets, they may be deliberately made that way so the plates & our gaskets can be rotated/flipped to block the coolant port if desired. If blocked, it appears SRP also includes a coolant bypass line. The principal purpose of the spacers was to act as a thermal barrier to heat soak from the engine. To some minor degree, additional clearance on the underside of the plenum may contribute to cooling due to increased airflow. SRP makes products with outstanding quality. I have long endorsed the SRP longer pressure plate bolts for use with aftermarket, lightweight flywheels in combination with the stock ZR-1 Pressure Plate.
Jerry Downey JERRYS LT5 GASKETS & PARTS http://www.jerrysgaskets.com 1994 ZR-1, Black/Black, Lingenfelter Aerobody, 416cu in, 3.91 gears, coil-over susp, Brembo brakes, etc. 2016 Black-Red, 3LT-Z51 Auto 8-speed. Last edited by A26B; 11-14-2016 at 11:00 AM. |
#9 |
Thanks for confirming the two gasket requirement.
#10 |
![]() Join Date: May 2010
Hey Lee,
How about $75 shipped USPS to my military APO address? Thanks for your consideration.
Craig "ZR-1 NO KA 'OI" "ZR-1 ICHIBAN" 1995 #228 Black/Black with Dunn Heads ZR-1 owner since September 2003 ZR-1 Net Registry Founding Member #0074 NCM Lifetime Member #2048 ![]() |
