10-21-2016 | #1 |
VERY high idle
Gentlemen:
New injectors, clutch, chip from Marc, plenum rebuild, headers, Corsa exhaust 18 months ago. Driving on country road today, passed a "turtle". Idle wouldn't drop below 4000. Had a heck of a time getting to destination! Checked everything roadside that I could, no change idle. Parked car for 1 1/2 hours, restarted, idle 2000 (normally 1100). Drove home, slow to return to idle with clutch in. Had similar problem when rebuilt and was IAC problem. Have a spare from Jerry. Before I tackle it, any other ideas of where to look? Cables are not stuck. Thanks, my friends! Ty Crossville, TN |
10-21-2016 | #2 |
Re: VERY high idle
I would look for vacuum leak.
10-21-2016 | #3 |
Re: VERY high idle
Thanks, nothing obvious, but will check further.
10-21-2016 | #4 |
Re: VERY high idle
Is the car stock? NORMAL idle is 1100????
10-21-2016 | #5 |
Re: VERY high idle
Marc Haibeck chip, new injectors from Jerry, Stainless Works ceramic coated headers with cats, Corsa stainless exhaust; everything else stock. 1992; have owned since new, stock idle has always been 1000 or so.
Thanks! |
10-21-2016 | #6 |
Re: VERY high idle
Stock idle is set to 650.
10-21-2016 | #7 |
Re: VERY high idle
Stock motor with exhaust headers should idle between 650 to 700. I think you have a leak somewhere or IAC is hanging up. Or, could be TB binding somehow.
10-21-2016 | #8 |
Re: VERY high idle
Will swap IAC tomorrow AM. Just looked for vacuum leaks and no obvious suspects. TB operating smoothly throughout range. Replaced all hoses and meticulously rebuilt just about everything when I had the plenum off. Had it so clean that you could eat under there. IAC swap should drop idle. Will advise. IAC was problem previously. Got new replacement from Jerry and it fixed problem. Swapped old one back in and it worked so I left it in. Hindsight 20/20. Should have left replacement from Jerry in! Was a helluva ride today! Had to drive 20 miles in second gear with 4000 rpm idle to keep it below 70 and got behind every stinking log truck in Cumberland County! Go figure. Sitting in town traffic at red lights idling at 4000 rpm with that exhaust system was an experience. One of the red lights was 50 feet from the county courthouse! Good thing that I have operated on half the cops in the county! Was 30 miles from home, so had no choice. Thanks for your help!
Ty |
10-22-2016 | #9 |
Re: VERY high idle
Sounds like you got it fixed. My in-laws are in Clinton County, KY. Byrdstown TN.
1988 KOH Prototype EX5023 sold 1990 ZR-1 #444 Convertible 1990 ZR-1 Black #966 1991 ZR-1 Quazar Blue #296 1957 Duntov SS Project Last edited by Blue Flame Restorations; 10-22-2016 at 12:16 AM. |
10-22-2016 | #10 |
Re: VERY high idle
Thanks, Brett. Very frustrating, thanks for your help. I have several patients from Byrdstown. I think that I will leave the password where we left it!
You are THE MAN! Ty |
