Old 10-21-2016   #1
Locobob
Default Coil Problem
So my car was running a little rough and progressively got worse so I did some testing. Initially I thought it was a fuel issue but after checking a few things I decided to ohm the plug wires through the coil packs. All were in the 15K range except the 8,5 coil which was OL. Pulled the plenum and here is the 8,5 coil. Lots of corrosion on the #5 tower, not sure what would cause this, all the other towers were nice and clean. All the plug wires ohm'd out good.
Robert
Old 10-21-2016   #2
Default Re: Coil Problem
Corrosion = mouse or meeses (if you prefer!)
Old 10-23-2016   #3
Young1
Young1's Avatar
That mouse is not prostate challenged to pee up the insulator boot! I shall give him due credit.
Steve Young
Second Owner
SOLD
SOLD
Old 10-23-2016   #4
Bob,
How does the #5 plug look? The question in my mind is whether the corrosion caused the misfire or is there a misfire in #5 resulting in the corrosion?
Old 10-23-2016   #5
Locobob
Bob,
The plugs all looked good
Robert
Old 10-23-2016   #6
So 5 was firing as good as the others then?
Old 10-23-2016   #7
Locobob
I doubt it considering I had an OL OHM reading from the #5 wire to the #8 wire. But I didn't see anything too awful at the plugs, they were all intact and had proper gaps.
Robert
Old 10-23-2016   #8
Locobob
Ugh, and now I'm having more annoying issues. The throttle appears to be hanging up sometimes. Won't rev down on coast down occasionally and sometimes the idle is a little high, both cured by a blip of the throttle. I pulled the airhorn and checked the throttle blades, cleaned up the IAC and reset the TPS to .54 (it was slightly low at .52). Don't see any issues when manually manipulating the throttle, it appears to snap shut just fine every time. Hmmmm
Robert
Old 10-29-2016   #9
Locobob
Well the problem is back, apparently the coil was not the root cause of the problem as wires 5 and 8 through the coil are once again OHMing at OL
Robert
Old 10-29-2016   #10
Locobob
The #5 spark plug looks a little cleaner than the others. It tested good on the multimeter, no sign of ground leaks and the center electrode was within the same OHM spec as the others.
Robert
