Old 01-17-2007   #1
ljobrian
Question trouble code 33
Can anyone tell me what a 33 code is? I don't have my service manuals yet, on backorder. The book that came with the tester says it is either a MAF high freq or voltage or a MAP high freq or voltage. The book is general corvette, not ZR-1 specific. Any help is greatly appreciated. Thanks, Leo
ljobrian is offline   Reply With Quote
Old 01-17-2007   #2
1990 quasar blue
Default Re: trouble code 33
MAP sensor issue.
1990 ZR1 #2574
Medium Quasar Blue Metallic
1 of 19
Old 01-17-2007   #3
Jeffvette
Make sure the MAP sensor hose is plugged in. You currently getting a high idle?
Old 01-18-2007   #4
ljobrian
Yes to the high idle and it is also hard to get started. The vacuum pump works like it is supposed to, but it is quite loud. Any thoughts there or where I could get a replacement.
Leo
Old 01-18-2007   #5
tccrab
tccrab's Avatar
Leo
Leo:
It sounds like your MAP sensor hose has come off.
Dig around behind the plenum on the drivers side, I'll bet dollars to donuts that you'll find that the hose isn't connected.
TomC
'90ZR1 #792
TomC
'90ZR1 #792
Honorary Pirate
[/B]
Old 02-07-2007   #6
ajaxajax2000
ajaxajax2000's Avatar
Guess you got it figured out by now. Just wanted to add to the others that I had exactly the same trouble, same code and sure enough, the tiny MAP sensor hose had come off it's place on the rear left side of the plenum.
Peter
'92 ZR-1, black on black, mostly stock (sold)
ajaxajax2000 is offline   Reply With Quote
