Old 09-14-2016   #1
tpepmeie
Default Cyl Head coolant plug
I know of at least two high-rpm engines which have had the rear coolant freeze plug blow out of the cylinder head. Once was about 10 years ago on a chassis dyno at BG. That was a 415 engine. And just recently a race car suffered the same fate, at speed. There may well be other examples of these plugs blowing out. I think it is usually the driver side.
Not going to take that chance with the new 427 build. 3x #2 drive screws on each head.
#attentiontodetails LOL.
Old 09-14-2016   #2
Default Re: Cyl Head coolant plug
Don't forget the crank plugs as well.
Old 09-14-2016   #3
tpepmeie
That's been done already, spot welded in place.
Old 09-14-2016   #4
Yep. Better safe than sorry. Secondchance and I found out the hard way
Old 09-14-2016   #5
I'm a believer! Missed a gear in a 1/4 mile drag race. That's when I discovered how much coolant pressure could spike, in spite of the pressure cap. Coolant blew through a thin spot as result of recent porting. I wouldn't have thought that would happen. But, it did. So, staking the freeze plugs really makes good sense.
Old 09-14-2016   #6
Blew out my D/S head rear freeze out plug on the LPE 385 on a 6.8K shift at BG one year. Coolant on the track at 110 mph can make for a bad hair day.
It's more common that you'd think.
Old 09-14-2016   #7
efnfast
But, if you stake the freeze plugs in place, aren't you defeating their purpose?
Old 09-14-2016   #8
secondchance
Yes. But very few ZR-1 owner would let the car sit outside in freezing temperature with only water in the cooling system. Don't you think?
Old 09-14-2016   #9
secondchance
Twice the fun!
Old 09-15-2016   #10
efnfast
And then there's that.
