Old 09-10-2016   #1
RichS
Default FX3 parts needed?
In the middle of redoing the rear suspension and putting 4:10 gears in. While waiting for the speedo gears, I figured I'd look into the rear shocks. The po replaced the rear shocks with KYBs. I went fishing in the frame and found the actuators were there. I ordered 2 new rear shocks from E-shocks. I know I'm going to need the clips to mount the actuators, and I think mounting bushings. I see they sell a metal gear, Do the new ones come gears on them? Also the lights don't come on in the info cluster. Is there a certain fuse? I need to check if they disconnected the module or pulled the bulb yet.
Pics of the cleanup.
1994 ZR-1 #198, sold
[img]https://live.staticflickr.com/65535/48400173802_2a6f122cfb_n.jpg[/IMG]
[COLOR=RoyalBlue]96 GrandSport#857[/COLOR],[COLOR=Red]Red Gut[/COLOR]
397 LT4, AFR heads,3:90 gears, DRM longtubes, Sepanek 700R4, Yank 3600, bla-bla...
Best ET w/396 & 6-speed 11.02 @126.57 w/1.60 60'
Best ET w/396 & 700r4 10.82 @124.87 w/1.48 60'
2003 DarkShadowGray Ford Lightning 460rwhp/550rwtq 12.11 @112.18 w/1.71 60'
RichS is offline   Reply With Quote
Old 09-11-2016   #2
Default Re: FX3 parts needed?
Rich yes the small gears come with the shocks but you will be missing the clips as stated and the actuator cups as well that ride on top of the shocks that the actuators mate to. Hopefully the PO only pulled the lights for the FX-3 system from the DIC.
http://www.captainzcnc.com is a source for the actuator clips and you can see pictures there on that website of the cups that ride on top of the shock as well. They offer a actuator rebuild service and have great troubleshooting advise for checking out the system. I would email them to see if they have the cups.
DRM is were I was able to get upper and lower poly shock bushings http://dougrippie.com/
They still sell them I just checked for you. If your interested Rich I do have a spare set of Actuators (1 Front and 1 Rear) that work perfectly that also have the cups and the clips you need in my parts crib. They are used but in fine shape. Drop me PM if you are interested.
Old 09-11-2016   #3
RichS
Pulled the dic and found the bulb and holder missing. I swapped it out with one off the top and checked the codes. There were 2 codes and they were for the rear shocks out of time, go figure.
So I need, bushings, clips and cups. And spare bulb holder for the dic..
Thanks!
Old 09-11-2016   #4
Well I have the clips the cups and the actuators. I was pretty sure the PO pulled the bulbs. I included the website for the upper and lower bushings. PM replied on Corvette Forum. GC
Old 09-17-2016   #5
Nope you posted it in Corvette Forum. thanks GC
