Hello , I recently had the cat on the right side break apart , i removed the exhaust and cleaned it out , now should I gut the left cat out also ? I figured it would cause an uneven back pressure issue and maybe a performance issue ? Any suggestions ? Thanks
If you do not have smog checks where you are......yes.......eliminate CATS.
Left Clickable links ![]() -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 09-06-2016 at 05:59 PM. |
![]() Join Date: Jun 2015
Agree, if you do not have to have them then balance those pipes. FTIW I found that Sea Foam does a great job of gutting cats. It happened both and the only times I ever used it.
#4 | |
