Old 09-06-2016   #1
gbrtng
gbrtng's Avatar
Default blower motor runs with key off
I've seen other threads about this issue and highly suspect the blower control module has croaked. Looking around on the web I see the part is common to 90 thru 92 with C68 (automatic) HVAC. Does anyone have a good module I can borrow to test my theory? Or an extra to sell?
Cheers,
Glenn
Old 09-06-2016   #2
secondchance
Default Re: blower motor runs with key off
Cheers,
Glenn
I had this happen to me. HVAC fan running at low speed even when the ignition was turned off resulting in mysterious dead battery. Unfortunately, I don't have a spare fan module.
Old 09-08-2016   #3
gbrtng
gbrtng's Avatar
one more time ... does anyone have a spare module?
Old 09-16-2016   #4
gbrtng
gbrtng's Avatar
fixed
Old 09-16-2016   #5
fixed
Nice........but........How was it fixed?
Old 09-17-2016   #6
gbrtng
gbrtng's Avatar
replaced the suspected failed module ...
Old 01-04-2017   #7
KFoster
Mine started that this past week. Fine one day. Next day I turn it off and the blower motor keeps running with the key off. Through def. Cranked it back up and switched it to vent. Shut it off and went back to def running. Unplugged the blower so my battery doesn't run down. Runs down after 6 or 7 days anyway. Where did you get your module?
1990 ZR1, 1987 Mustang GT (since new), 1973 DeTomaso Pantera, 1987 928S4
Passed on: 1984 930S (gray market), 1988 Mustang Coupe Trooper car(drag)
KFoster is offline   Reply With Quote
Old 01-04-2017   #8
gbrtng
gbrtng's Avatar
Order # 2428093
Order Date: 09/12/2016
Thank you for placing your order with Corvette Central. We are currently processing your order
and will send you a confirmation email once your order has been shipped.
Our computer system shows the following item(s) are in stock and ready for shipment:
Qty: 1
Item: 454019
Description: HTR BLOWER MTR CONTROL MODULE
I think there were some used ones on ebay but opted for a new one.
Old 01-04-2017   #9
KFoster
I got a catalog from them yesterday. I'll look tonight. I appreciate the help. Thanks.
Old 01-04-2017   #10
Would a bad module also cause the blower to run slower than it should? And has anyone run into this situation before?
