09-05-2016 | #1 |
Cam Position Sensor
Anyone know where I can get a new cam position sensor?
Robert ZR-1 Net Registry Oregon State Director 91 ZR-1 #431 Black/Black LPE 368 |
09-05-2016 | #2 |
Re: Cam Position Sensor
http://www.rockauto.com/en/moreinfo....041297&jsn=601
$182 I was looking through the members ZR-1 parts list catalog ~680 page PDF, trying to confirm that this is OK, but I haven't found it yet.
1991 ZR-1 #1438 Black/Black & Red |
09-05-2016 | #3 |
I think Standard is the brand I got a few years ago.
09-06-2016 | #4 |
Well thanks for the link but I'm still SOL... looked at it earlier and it was in stock, went to order tonight and now it's showing out of stock
09-06-2016 | #5 |
Found one, thanks for the tip!
09-06-2016 | #6 |
Where did you find the Camshaft Position Sensor? Does it come with "O" Ring?
I know Jerry has the Camshaft Position Sensor "O" Ring. |
09-06-2016 | #7 |
Found one on Amazon, hopefully it comes with the oring, just kind of assumed it does.
09-06-2016 | #8 |
Cam Position Sensor
I prolly missed it.......but how you figure out your camshaft position sensor was bad?
Could be connection, wires, DIS. After tracking down Blown INJ1 fuse issues for a week and after removing plenum five times ........I am convinced anything is possible [emoji3] What I did is put Ohm meter on down side of INJ1 fuse and starting at 1,200 Ohms watched the Ohm meter as I removed the Plenum. Especially as I disconnected various connectors or wiggled various wire looms/wires. Found the 14pin DIS connector movement caused Ohm meter to go to near zero Ohms ah ha.........but still do not know exactly why.......I know where problem was but not What problem was lol lol lol Sent from my iPhone using ZR-1 Net Registry
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 09-06-2016 at 03:47 PM. |
09-06-2016 | #9 |
The sensor I got wouldn't allow the small stock sensor guard to fit so I left it off. To get the guard back on the car you will need to modify it,trim it a bit.
09-06-2016 | #10 | |
