![]() Join Date: Mar 2013
Trying to get my hose on the fuel rail schrader valve is a PITA. I was wondering if anyone knows of a 90 degree fitting that will screw into the test hose and over the fuel rail valve? All I can find are 90 degree fittings with a quick disconnect on the test hose side.
1995 ZR1 #159 Ported,Corsa,4.10 Rear, Dual Disc RAM Clutch, Alum Flywheel, Haibeck Chip, ZFDoc Plates, Relocated Battery 400 rwhp 1992 ZR1 #280 Ported, Locked Secondary's, Flowmaster Exhaust, Haibeck Chip, 375rwhp 1996 Collectors LT4 (Stock) 1972 Convertible 434 Small Block 572 rwhp |
![]() Join Date: Jan 2015
This is from memory so may not be accurate - I think it is a standard thread (something like 3/8-24 or AN-6. I had a fitting that fit, and I was able to cobble together a pressure tester. I think I temporarily removed the inner Schrader valve during the test.
I'll probably be around on Saturday if you want me to check to see if I have something you can borrow. |
I was looking for an adapter to keep on hand. I guess if the valve is removed for testing, that would open up some possibilities. I have of bunch of misc. fittings I will try. Thanks for the idea!
![]() Join Date: Feb 2012
Replacement Bicycle Pump Head?
Thread size is not big enough.
![]() Join Date: Mar 2007
check nitrous fittings for fuel rails.....or speed shop
![]() Join Date: Oct 2004
GM & standard Schrader I'm quite sure is .305 - 32 TPI (sometimes .302 is mentioned also and that I believe comes from a Metric conversion).
BUT this ain't correct for FI Schrader external. I believe the terminology for the FI Schrader is just "large Schrader". Last edited by WVZR-1; 09-03-2016 at 02:16 AM. |
#8 | |
![]() Join Date: Dec 2003
#9 | ||
![]() Join Date: Jul 2007
#10 | ||
![]() I was going to try the AC connectors ![]()
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 09-02-2016 at 10:59 PM. |
