![]() Join Date: May 2008
I have a '94...#445...it has been sitting in my garage for a couple of years...it was running at the time of storage. I had been keeping it on a trickle charger and would start it up occasionally. A few months back I tried to start it...no response...not even a starter click sound. Went and got a new battery, thinking that was the issue...installed the new battery...still, not even a starter click. Took the battery back for an exchange thinking that might have been the issue...they load tested it and said it was good.
Putting out a call for mechanically inclined ZR-1 owners in the area/vacinity of East Texas...Beaumont is a nearby larger city...for reference purposes. I will make it worth while for any on-site assistance/help to get it running again. At this point I'm concerned about fuel stagnation becoming a bigger issue later due to not being able to keeping it running. Thanks, Clint |
Are the interior lights coming on ? The start up lights in the DIC? Is the security light flashing ?
Or are you reporting you have ZERO power. Or POWER but no start ?
#3 | |
![]() Join Date: Nov 2007
Here is a link to an article by Marc Haibeck regarding starter issues. Some very good info here, and in particular his procedure for "waking up" a starter that may not have been exercised for a while. Below is a starter circuit diagram of the 93+ cars. In RED is the high current path to the starter. The GREEN path is that of the relay current; relays that handle the heavy current. (You may read a lot about a "installing a RELAY" in some threads, including a relay schematic. However, this modification I designed for the 90-92s and shouldn't be confused with the 93-95 cars. (HOWEVER, that isn't to say your clutch switch couldn't be the problem: just not nearly as likely.) ![]() Keep us posted... Last edited by Paul Workman; 08-17-2016 at 03:18 PM. |
Thanks for the quick replies...in my initial post I should have added that the complete electrical system is dead...and that I had already suspected a single point of failure...or at least that's a logical assumption for me.
I guess it's time to break out the test light and VOM, and some troubleshooting. Thanks for the schematic that was posted. |
Id pull the battery and start with the cables. You mentioned this was stored for a while so rodents chewing up the wires would be an area of concern.
![]() Join Date: Feb 2006
Start at the terminal block behind the battery - corrosion is your enemy - that's the distribution center for all the vehicle's power.
any mice in that garage?
