**UPDATE SOLVED !!**
It was the clutch switch ! Snipped the wires and connected them together and she cranks beautifully. Thanks again to everyone who put up with me typing my thoughts over the last week and that chimed in. Very much appreciated this forum is awesome ![]() ** Original post ** I guess it was only a matter of time after reading about no crank threads here and there on the forum ! First time it's happened to me.. Finishing moving.. Last thing was to get my ZR-1 home. Stopped for gas and now she won't fire up. Car is a 1994 * Security doesn't blink when the key is in so thinking not vats. But looks like the bypass is next on the list for one. Clutch pedal.. I can't seem to see any photos on where to look.. Does the panel need to be removed to access the switch ? I have no tools on me but i do have someone to help push ! Will try that shortly. Any input is appreciated ! **UPDATE** 08/15/16 11am Again in a nutshell. Cranked and fired every single time over the years until this happened. My experience tells me if it was the starter it may crank sometimes .. I've personally never had one die completely but there's always a first time. I did just do the clutch switch bypass. 5 mins and done but still no start. https://youtu.be/d_rI6IdEKsg **UPDATE 08/15/16 2pm** Thanks to all your guys help so far at least I am now able to fire the car up until I get it sorted out ! ![]() Harness under the ECM. Purple wire I added a 8awg quality wire I had laying as spare. Touching this to the battery positive terminal cranked the motor instantly. Added a rubber cap and taped it and the wire later for extra protection. Easily hidden out of sight. Now to figure out why the starter isn't getting power when I turn the key.. Hmm.. Last edited by 5ABI VT; 07-06-2017 at 04:04 AM. |
![]() Join Date: Apr 2004
Any chance you can give it a push and slip it in 2nd gear to get it going and home?
#3 | |
Managed to push start it I'm on the way ! Couldn't be more relieved just need to get it there and I can tear into it this week. Will search the threads for info sorry for asking yet again !! |
If it's push starting is clutch switch the likely culprit ? I did just pump the clutch pedal 10000x just a month ago
![]() Join Date: Aug 2006
Try starting once the car cools down. I had the same happen to me. As the starter age heat soak, at times, disables it. Rebuild or a new starter may be the solution.
#6 | |
![]() Appreciate the input ! |
![]() Join Date: Jan 2015
If you need a semi-quick fix to prevent being stranded due to no-start see this thread:
http://zr1.net/forum/showthread.php?t=24767 That will allow you to send 12v directly to the starter, bypassing everything that might be causing the problem. I did the above and lived with it for a brief time until I could do the VATS bypass and relay mod, which fixed my issue. |
Pull driver’s side hush panel.
Locate striped purple wire that goes to clutch switch. Look at switch and note the color of wire coming back up.(Yellow??) If you found them—the jumper will go from the Yellow to the purple stripe. You should be able to jumper them right there without messing with that ##*!!$ clutch switch. I used a 3 in #12 wire with terminals (from Radio Shack number 64-3133) on the end and unplugged the wires going to switch and plugged in the jumper wire. Use a 12 ga wire at least as it does carry a heavy current load which is why the switch fails, it gets hot and the resistance across the points stops current flow.
#9 | |
#10 | |
