Old 08-08-2016   #1
BlackZR1
BlackZR1's Avatar
Default Window Switch Repair
Sharing some pics after repairing my intermittent passenger side power window switch.
Disassembly is straight forward and fairly obvious. The switch itself “snaps” out of the door panel, then pull the 2 harness connectors out of the hole far enough to disconnect them. Remove the switch with the 2 short pigtails. Now on the bench, need to remove the 6 wire terminals (take note of the wire colors and positions) unsolder the capacitor, remove the 1/8 turn bulb with holder, then remove 2 screws to remove the outer case. Next remove the up/down lever assembly by unlatching the 4 small latches. The 2 latches on the right hand side in the picture are hard to access so I used a utility knife to shave the corner off allowing an opening for a very small screwdriver to pop the latches. There are no springs to pop out just the loose contact wipers which come out and allow cleaning. You can see how dirty mine were. After cleaning, add some dielectric grease to the contacts, lever and reassemble.
Seems to be a limit of 5 pics. I will post last 2 on next post
Roger
1990 ZR-1 #2699
Black on Black
15,000 miles
Full-time secondaries, 4.10 gears, C-beam plates, ported top end
BlackZR1 is offline   Reply With Quote
Old 08-08-2016   #2
BlackZR1
BlackZR1's Avatar
Default Re: Window Switch Repair
Last 2 pics below.
Roger
1990 ZR-1 #2699
Black on Black
15,000 miles
Old 08-09-2016   #3
Roger neat that you can do this. Those grey button replacements are getting rear HTF these days. GC
