Been looking on fleabay for 4.10s and noticed that Jeep uses the same gear for the rear. The Dana 44 gear listed has the same cross-reference #. Am I missing something because these gears are substantially less expensive. On CF someone commented that they had in fact installed the Jeep gear.
![]() Join Date: Nov 2007
#3 | |
![]() Join Date: Oct 2004
BRAND and PART # ???????? |
Here's the fleabay link to the Jeep 4.10. It's a Spicer unit. In the notes u will see a X-ref to 2007772 part #
http://www.ebay.com/itm/RING-AND-PIN...hSFk5t&vxp=mtr Now here's a Spicer D44 4.10 from Jegs. Manuf # is 2007772 http://www.ebay.com/itm/Spicer-20077...1W5waf&vxp=mtr One describes a 12 bolt while the other appears to be a 10 bolt. HMM. |
Dom,
You need the 29 spline HD pinion, not the girly 24 spline like the one shown in the ebay listing. Otherwise you might end up like this example after your LT5 has its way with it: ![]() ![]() BTW from what I understand there are some models of Jeep Grand Charokee that also use the 29 spline pinion as the the Corvette & Viper Dana 44HD.i
Phil Wasinger 1994 Torch Red ZR-1 WAZOO Member George Braml Intake Last edited by Jagdpanzer; 08-25-2016 at 10:22 AM. Reason: corrected to 29 spline pinion |
![]() Join Date: Sep 2012
Maybe the SRT8?
That gear package appears to be a potential "FIT" but I believe it's likely done with only 1/2 ring gear bolts OR it's multi pattern for 7/16 and 1/2 BUT NOT 3/8. I need to dig just a little deeper but some builds I find mention SOME early '07 builds were 7/16 and later all 1/2 and the differential case is recommended/suggested by Dana/Spicer when using.
I should be able to nail it I think. I've used only some Dana information to try and ID it for sure. The option was a "specialty" package offered for only towing and I actually doubt many CMC/Jeep people are very familiar. serious JEEP people for sure are. ***I believe it's likely 7/16-20 & 1/2-20 multi-fit and there seems to be many after-market equivalents that are very inexpensive. A buy might require confirming packaging!! ***I may have spotted one for something less than maybe $225 - much less LOL less than $200 from Summit Last edited by WVZR-1; 07-26-2016 at 07:06 PM. |
Dom,
this looks like an excellent deal on a set of Mopar Viper PN P5007043 4.10 gears http://www.moparonlineperformance.co...p/p5007043.htm
#9 | |
Phil/Dave, Your help on this is way much appreciated. Maybe this could open it up for others as well. Thx guys. |
#10 | |
If you're looking to buy a differential that's built you need to check the hex of the pinion nut 1 1/8 is the lesser D44 (1.146/26) - I'd say stay away unless it's a real deal! The D44HD hex I think Dana specs at 1 9/32 but 1 5/16 I believe gets it done and is the dimension most often mentioned. I didn't check any further - as to the bearing surface diameters and lengths. The MOPAR gear Phil pointed out is a good buy I'd think. These could still be some old NOS stuff machined in the USA. Maybe NOT! Last edited by WVZR-1; 07-28-2016 at 07:51 AM. |
