94 ZR1
Has anyone else had trouble getting their car to work on an inspection dyno? I'm attempting to get my inspection here in Texas, and the tech could not get the car up to speed on the dyno. This is the second shop I've visited with the same result. He said there was an "ABS like noise" coming from the car. He turned the traction control off. I don't know what else it could be? |
#2 | |
![]() ![]() Join Date: Nov 2007
Just a thought!
Good carz, good food, good friendz = the best of timez! 90 #1202 "FBI" top end ported & relieved Cam timing by "Pete the Greek" Sans secondaries Chip & dyno tuning by Haibeck Automotive SW headers, X-pipe, MF muffs Former Secretary, ZR-1 Net Registry Last edited by Paul Workman; 07-24-2016 at 02:47 PM. |
![]() ![]() ![]() Join Date: May 2007
Id offer to drive it for them. That's what I had to do in the past as the kid didn't know how to drive a standard correctly
Thanks for the suggestion. I'm fairly certain that the parking brake was disengaged while he was running it. I watched him disengage it when he moved the car to the inspection bay.
I may have chalked it up to incompetence if it was just one shop. But both shops I took it to said the same thing. i initially thought it may have been user error, but I don't believe that's the case now. It's almost like some system is interfering and cutting out power, which is why I was thinking traction control. But it still had this issue with traction control disabled. I'm really at a loss...
#6 | |
![]() Join Date: Feb 2011
My 91 drove fine on an emissions dynomometer with only the rear wheel turning as did my old 1995 C4 coupe with the traction control. I have never heard of C4 having a condition with a pair of wheels not turning that caused the ABS/TC to freak out.
#8 | |
![]() Join Date: Jun 2005
Maybe the TCS switch is defective. When he turned TCS off, was the "Traction Control Off" light on and was the tech getting the vibration feeback though the accelerator pedal one gets when TCS enables? If not, it might be that even though he pushed the switch, TCS was still enabled. There is an easy way for you to test this. Find a wet road or wet parking lot. Turn TCS off, then try and spin the tires. You should be able to do that easily. If TCS is on, you won't be able to spin the tires. You will feel the accelerator shaking and the rear brakes enabling.
Hib Halverson Technical Writer former owner 95 VIN 0140 current owner 19 VIN 1878 Last edited by Hib Halverson; 07-25-2016 at 04:19 PM. |
#9 |
![]() Join Date: May 2006
I haven't had any problems and just had mine inspected in June. Last two times I had it inspected at Kwik Kar in Keller and Roanoake.
#10 |
I had the same problem when I went through the test the first time. My solution was to deactivate the traction control.
