Old 07-20-2016   #1
Chris26
Default INFL Rest Bolt Problem
Tried to remove the bolts only to have one of them strip into the frame....
should i just cut the bolt head off with a dremel.....I don't want to shake up that
sensor too much.....
Chris26 is offline   Reply With Quote
Old 07-20-2016   #2
Scrrem
Scrrem's Avatar
Default Re: INFL Rest Bolt Problem
That may be your only option at this point. I believe the nuts are spot welded inside the frame. Did the bolt/nut strip or did the spot welds on the nuts break loose? If the latter, hopefully there is a frame hole close by to get a new nut inside the frame.
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 07-21-2016   #3
Chris26
Yup the spot weld (grommet) is toast...I got the bolt out....
