Old 07-18-2016   #1
Default Euro Taillamps installed
Yes, I was finally able to finish and successfully install a set of Euro lamps. Found a set laying around on a 92 convertible w flat tires. I was able to do the install w cutting ONLY two wires and setting up an easy conversion back to stock if desired.
I'll include a few pics next. Thanks to =Jeff= and to WVZR-1 for their posts on similar threads. Everything works as it should.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 07-18-2016   #2
Kevin
Kevin's Avatar
Default Re: Euro Taillamps installed
love the euro tails but have never put them on my car. seems like a lot of work but they do look awesome
Old 07-18-2016   #3
Scrrem
Scrrem's Avatar
I love mine, Mark H. helped me getting them wired up when he was up in WAZOO land. Love the look.
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 07-18-2016   #4
BTW, did anyone realize they now make LED bulbs that replace our brake/taillamps? Anyone use them? Not cheap at AZ. $20/pair. I'll post some pics soon.
Old 07-18-2016   #5
Actually Dom $20 a pair is pretty cheap for any kind of quality. Some of the new blubs are non error and have a resister built in
Awaiting the post up
Old 07-18-2016   #6
Fully Vetted
Fully Vetted's Avatar
Another mod I've always wanted to do...
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
Old 07-18-2016   #7
BigJohn
BigJohn's Avatar
I don't know, kind of glad I don't live in Europe.
Old 07-18-2016   #8
I think these lamps work best w color in the red family, JMHO.
Here's the finished product. Everything works as it should. Red for brakes and running lights, Amber for signal and 4way.
One issue I overcame was that 2 of the lights were missing dividers between top and bottom so I made some from sheet aluminum. Works great.
BTW, these are genuine GM parts, not replicas from Mid America, not that it really matters to me much.
I was able to disconnect the white wire from the brake switch without cutting it. I removed it from the harness connector at the switch. The brake applied signal comes from just behind the halo pillar light and routed a line to the back.
Old 07-18-2016   #9
So are you going with the LED bulbs?
Old 07-18-2016   #10
I am not right now, which is why I asked if anyone has used them. W Euros, that's $80 for 8 lamps. I went on Amazon and fl a bay to see if I could find the same ones I saw at AZ.
