Old 07-11-2016   #1
Dds1990
Default Secondary actuator & Plenum gaskets needed
In need of a secondary actuator and plenum gaskets. Secondarys not working code #61 and previous owner advised problem with the actuator. Already replaced vacuum pump and doesn't appear to have vacuum leak. Also should I replace the vacuum lines under plenum and does anyone sell them/ kit? Thanks in advance...Dds1990 #0106
Dds1990 is offline   Reply With Quote
Old 07-11-2016   #2
Vette73
Default Re: Secondary actuator & Plenum gaskets needed
Jerrys gaskets has all the parts you need ....
Vette73 is offline   Reply With Quote
Old 07-11-2016   #3
Dds1990
That's a start...Thank you
