Old 07-02-2016   #1
Regimof
Default Put it on a rack... concerning tire wear
I have a friend that has a shop and I convinced him to let me put the Z on so I could clean up underneath and see what's what. I've had it on a couple drives and figure that the cobwebs should be shaken out and any new issues might present themselves.
So after we looked online for 25 minutes on how to get a c4 up correctly, we lifted it and the first thing we saw was the rear tires are toast. That happens. It's due anyway. The concerning part, for me, is how they wore. The insides on both tires were considerably more worn..one actually has wires showing... and the outsides are fine.
Is this something I should be worried over? It doesn't seem right, but I not a smart man. I'm not familiar with these fat tires.
One more thing... occasionally when I get on it, that brake warning light comes on. Like I have the parking brake on. Nothing happens.. just the light. Thoughts?
Regimof is offline   Reply With Quote
Old 07-02-2016   #2
BigJohn
BigJohn's Avatar
Default Re: Put it on a rack... concerning tire wear
When set up with racing camber, your tires will wear more on the inside like you described.
Old 07-02-2016   #3
Check you brake fluid level at the master cylinder. As to inner tire wear make sure your car has a 4 wheel road force balancing and alignment. Toe or camber is off. That is not normal meaty tire or not. GC
Old 07-02-2016   #4
Corvettes White
Look for worn bushings on the rods.
Corvettes White is offline   Reply With Quote
Old 07-02-2016   #5
Regimof
Where does one acquire a 4 wheel force balancing
Old 07-02-2016   #6
Regimof
I'm not sure if this helps, but it only had 24xxx miles on it
Old 07-02-2016   #7
You have to look around for shops that perform it and have the equipment. I'm a believer as I had to get mine all redone when I went to coil overs and it solves abnormal tire wear unless the car is set to a particular setup for autocross etc.
Old 07-02-2016   #8
RussMcB
Sure sounds like way too much negative camber to me. Or not enough hard cornering. :-)
Our tires are so fat, proper camber is more important than for most cars.
Russ McBride, [COLOR="Red"]Car Sold 8/2020[/COLOR] #1635, Marietta, GA USA, 1991 ZR-1, #766 (bought 1/1/2015)
MS3-Pro, OBX, SW X-Pipe, Borla, Hurst, SLP, Goodyear F1 GS-D3, Kenwood. HOTB 2016Q3
[IMG]http://zr1.net/forum/picture.php?albumid=316&pictureid=2873[/IMG] [IMG]http://zr1.net/forum/picture.php?albumid=336&pictureid=2985[/IMG]
