Old 06-18-2016   #1
riselly1
Smile Got a few codes.
Hello, my name is rick and I am new to the ZR-1 LT5 world. Let me just say i was a little wairy when i purchased my ZR1 back in march but after the first drive i was hooked and do not miss my 996 at all, this thing just rocks !! http://zr1.net/forum/images/smilies/eusa_dance.gif
Anyways, I have put a little over 2K miles with no issues but just yesterday my Z seems to be feeling a little sick. It sat for about a week and when i started it i noticed a fluctuating idle that looks like its about to quit but the car saves it, sometimes it does stall but i can start it right back with no issues. heres the list of codes i pulled.......
12
13: Left oxygen sensor open
14: coolant sensor high temp
21: throttle position sensor high TPS
22: throttle position sensor low TPS
23: manifold air temperature MAT temp low
41: cylinder select error
42: electronic spark timing EST system error
43: Electronic spark control ESC system error
34: mass air flow sensor low MAP
33: mass air flow sensor high MAP
32: EGR system failure ???
31: Cam sensor missing or too many pulses
12
http://zr1.net/forum/images/smilies/icon_cry.gif
As i said before the only thing differently was it sat for a little longer than usual and HAD to put some of that cheap "Westar" gas instead of SHELL. Also when i purchased the car it came with the secondary port throttle vacuum unplugled and the car refused to go past 140. I have plugged it in since but have not done another fast run so idk.
Any advise fellas??
riselly1 is offline   Reply With Quote
Old 06-18-2016   #2
Kevin
Kevin's Avatar
Default Re: Got a few codes.
I've never seen that many codes in even the worst maintained car. Reset the ecm, go for a drive and see what comes back
Old 06-18-2016   #3
G8nightman
G8nightman's Avatar
Second Kevin's post.
90 Chevy ZR1 LPE #2315 'SOLD'
90 Chevy ZR1 LPE #2774 'SOLD'
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
95 Chevy ZR1 #338 'SOLD'
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
G8nightman is offline   Reply With Quote
Old 06-18-2016   #4
gbrtng
gbrtng's Avatar
Looks like your ECM pooped the bed - try to locate a loaner replacement to swap in.
Old 06-18-2016   #5
I think you may have a lot of stored codes, agreeing with Kevin. Disconnect the battery for a couple of minutes, drive it for awhile, then check to see what new codes are set, if any.
FYI, if you have multiple codes, always start diagnostics with the numerically lowest code first. Resolving the numerically lowest code first will most likely take care of the others as well.
Old 06-21-2016   #6
riselly1
Hey ladies I took a little longer to respond than expected. I tried a few combinations between "good" and bad gas, resetting the computer before, during and after and this is what I currently have:
Good news; the codes are gone. I now have code 44 and 54 for the tire pressure monitor. And service engine blinks 12 only
Bad news; while idle is steady during hard breaking the car stalls or wants to quit with mild braking. Power isn't always there, and I feel like it back fires a little when off the gas. Tried with power key on or off.
Sounds like a vacuum doesn't it??
Old 06-21-2016   #7
Congrats on your ZR-1 I hope that you get everything taken care of.
Just out of curiosity what year?
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 06-22-2016   #8
riselly1
Hey thanks ! Its a 91 burgundy with 34k miles on her.
Old 06-22-2016   #9
IAC may need to be cleaned, You need to put it on a scanner it could also be a lazy O2 sensor or TPS. A scanner would point you in the right direction.
Steve
1990 Red/Red #1473
Old 06-22-2016   #10
BigJohn
BigJohn's Avatar
mouse nest?
